The things you don't "budget" for will always cost more than the budgeted items....So by you figuring 7100 as a "budget", figure about 8000 for the "unbudgeted - unforseen" items and thats 15100....sounds about right....
i have found a fj40 i like for sale. the buyer is asking $2500, might be able to get it for a few hundred less.
problems:
1) both rear quarters rusted
i was going to buy new panels and weld them in place. how hard is this? only welded about twice.
2) rockers rusted
planning on replacements as well
3) engine has been cleaned up. 119-120psi on all cylinders. said it runs well
how long would you expect till it would need a rebuild
have not looked to much into it, he said it will be sold by thanksgiving (he's hoping), if not i plan on getting it if all goes to plan.
heres what my plan for it would/will be:
1) fix rust spots
2) SOA lift
3) 35's and rims
4) possibly power steering (wasn't 75 or 76 first year for PS?)
5) line-x, paint
any advice will be great. this would be my first vehicle to work on in this depth but i want a vehicle so i dont mess up my daily driver
Be patient. You can find a better base rig for not much more. I bought mine here in Dallas a couple years ago for $4k and it was a lot better to start with.
I didn't read all of the other responses in detail and I didn't see that anyone mentioned the compression readings you quoted so forgive me if this is a repeat. I think 114 psi is the minimum according to the FSM and you said you had 119-120 so you're not too far off the minimum. I know it can run for years more at 119-120 or even 114 or lower but just because the motor is nice and clean looking doesn't mean it isn't tired and I'd say it's tired. I'd pass and find one with a more solid tub and/or a less tired engine.
Good luck,
Pete
car $2500
lift $500
wheels/tires $400
paint/line-x $2500
metal work $ 600
miscellaneous $700
In my opinion, most of your numbers are too low. You are going to buy four 35 inch tires AND rims for $400? BF Goodrich All Terrain T/A KO tires listed by size Are they going to be new? balanced and mounted? Do you have to sandblast and paint your rims? etc
tires/rims used. i live in texas there are mexican tire shops everywhere. they have crazy deals always. already have BFG AT's on my DD, i like em but this rig is going to be my offroad toy so going for a mud terrain, most likely just BFG's since their easy to find at the mexican used tire shops. rims i plan on painting eventually, but thats not any where near the top of my priority list so thats more of a when i finish what i need to get done i will get around to it
Most 4" SUA lifts have been reported in the $800-1000 range before shipping, and the general feel from these boards is that SOA is slightly more expensive, and may involve other things that you aren't adding up. https://forum.ih8mud.com/40-55-series-tech/135736-average-cost-including-labor-soa.html
Plan on researching SOA ALOT more i really want 6-8" of lift, might as well AAL or a new leaf pack and get the height i want, since i will already be spending money on driveshafts. forgot to calculate that into my budget as well. i have been revising it like crazy. so my old numbers beside the 40 cost is all wrong.
Metal work, especially in that rig is going to be more than $600 to get it to "looking good" as you want. A pair of quarter panels is over half of your budget once you have them shipped. Quarter Panels
And then you said you wanted to add power steering which isn't that expensive but also isn't free. All the little things add up.
Power steering i would not do for a while, my first goals will be getting it looking good
Add in tools that you will buy, unforseen things, shipping, a Grant steering wheeletc, and I would agree with others that have posted here that you probably need to double your budget.
i already said, that budget of 4k is my starting budget meaning i can afford to spend that right up front. so 4k is not my max, its what at the moment i can do. beginning the new year my budget should be another 1,000 bucks atleast so i should be at around 5k in januarary i know my numbers are low, i researched a little more, i plan on doing alot of research on a SOA i want to be able to possibly run 36's or 37s eventually way down the road, what are the max tire size recommended for stock axles? 35s?
I'm no expert, and I'm a mechanical idiot, but I'm in the exact stage you are -- Doing research and trying to see what this is all going to cost me.
Please don't take offense, but I think you need to search these forums more, research some of these mods you are talking about, and then research what they are actually going to cost you on the internet / local shops.
my friends a professional welder, so any welding i can't handle a 12 pack of beer will cover and he will do it for me. the shop i had some work done on my DD cuts me crazy deals on certain parts since i spent so much money with them last spring. but i know, i have researched more, and numbers will grow. from my "rough" calculations its looking a lot higher than my original thoughts, but i have decided to search for another cruiser with less rust to save money on body work. [/qoute]
did you find it thru craigslist? or ebay?
keep looking........... you will spend wayyyyyyyyyyy more than 4 K just to get it ok...
I'd pass! Why don't you take a short trip to California. Check this one out.
1968 toyota landcruiser fj40
that one looks REALLY good. i'd probly spend a 1000 bucks in gas and hotel, but 2k looks like a steal for it. ill email the guy and get more photo's. i just got off craigslist 2 seconds ago but didn't check out california. but i did look at about ever state in central U.S.
good find
dont forget transport options. I got mine from Col to Mn for less than 1K. But sometimes the drive home is a huge part of the deal...... Gatta say its pretty fun to see the big rig roll up in the hood though....
Looks like a much better rig.....for 2k that would be a great start
bought a 40. sending payment to the guy, and having it shipped.
things needed to get/do:
1) hard top
2) ambulance doors
3) finish steering set up
4) finish exhaust (only has manifolds right now but has 350 small block)
5) shocks
6) drive shafts probly will need to be lengthed (what kind of shop do i bring them to?)
7) little rust in rear quarters
question about hy steer that i didn't find an answer for in the FAQ's. if you get a hy steer from 4x4 labs or any where really, does it just bolt on and you need to modify your steering from the PS box, or will it bolt up just like it did before the SOA? thanks for the help, i know i will be using it ALOT
