ARCHIVE New - Toyota 9.5" 4.88 Gears - Just Differentials
Cashmere WA
Website
www.justdifferentials.com
Nitro's new Toyota 9.5" rear 4.88 ratio gear supersede part number TLC100-488-NG. The previous TLC100 gears had a 29 spline pinion, our T9.5 gears are 32 spline. Older models can now upgrade to these gears with our conversion yoke YOKT60060 and Master Install Kit MKT9.5, for a pinion spline upgrade.
Vehicle Applications:
**1998-2007 models will require yoke YOKT60060 and Install Kit MKT9.5**
Rear Diff:
1998-2007 Land Cruiser 100 Series, HDJ100, HZJ105, FZJ100, FZJ105, UZJ100
1998-2007 Land Cruiser Burbuja & Autana (Venezuela)
1998-2007 Land Cruiser 70 Series
(matching front gear T8R-488R-NG)
2008 & Newer Land Cruiser 70 Series
2007-2014 Tundra w/ 4.6L 1UR-FE or 4.7 2UZ-FE
2008 & Newer Land Cruiser 200 Series, GRJ200 URJ200 VDJ200
(matching front gear T9R-488-NG
Also available in complete 4x4 Gear Package Kits with front and rear ring & pinions and front & rear master install kits:
Features:
  • 2 Year Warranty*
  • 32 spline pinion upgrade for 1998-2007 models
  • 8620 gear forging
  • Precision machined
  • Triple lapped
  • Rockwell hardness tested
Tech Note:
32 spline pinion, is a direct fit for 2008 Models, is an Upgrade for 1998-2007 vehicles, which will require YOKT60060 & MKT9.5, see Vehicle Application tab for more info
Rear Diff:
Features:
  • 2 Year Warranty*
  • 8620 gear forging
  • Triple lapped
Tech Note:
So can the pinion on my rear 80 series axle be upgraded to the 32 spline pinion? Would be awesome if nitro offered a kit to install 35 spline axle shafts as well to fj60 and fj80 axles.
As stated they are only for the 98+ style carrier.
New Toyota 9.5", 4.88 Gears For 98-Present Land Cruiser 100, 200, 79 Series, and Tundra - New Products - Nitro Gear & Axle
That said the actual 3rd member housing is the same on all years, but the 98+ have a different offset, bolt pattern, and inner diameter. It is possible to use these gears in 97 & older model diffs IF you use the 98+ style locker, and upgrade the axles to custom 32 spline axles.
This is what we did on the 80 series rear in the BJ73:
Justdifferentials / Nitro Gear Project "Inigo" 87 bj73 Landcruiser LHD, from Spain
