New to me GX460 OBD2 error code party. (8 Viewers)
New to me 2010 GX460 with 130k. I purchased the GX last week, everything feels tight on it, runs well, everything works, interior and exterior are in good shape (excellent for a car that has lived its life in Brooklyn).
I picked up a BT OBD2 adapter which was delivered yesterday (LeLink OBD2 Diagnostic Tool) and using OBD Fusion with the $10 Toyota add-on.
C1201 - Engine Control System Malfunction
C1422 - Master Cylinder Pressure Sensor Zero Point High
C1456 - Control Pressure Sensor Zero Point High
P0504 - Brake Switch "A"/"B" Correlation
OBD2 equipped cars are new to me, so this is my first time dealing with codes.
A little research suggests that the P0504 issue is probably just a problem with the break indicator switch which is easy enough to diagnose and fix.
I found some information suggesting that it is possible the C1422 and C1456 codes may be remedies with a Zero Point Calibration (if I am lucky?)
The C1201 is obviously the concerning code.
I have not been able to get the OBD2 scanner to read information from the tire pressure management system. Not sure if its just my BT adapter or something else.
There are no dash lights on, no check engine light or other warning.
If anyone could suggest next steps to diagnosing the issues that would be super helpful. Thanks all.
Here is the top part of the report exported:
Diagnostic Report​
VIN: JTJJM7FX2A5014473
Manufacturer: Lexus
Model: GX460
Option: 4.6 L
Year: 2010
Monitor Status Report​
NameContinuousAvailableComplete
MisfireYesYesYes
Fuel SystemYesYesYes
ComponentsYesYesYes
CatalystNoYesYes
Heated CatalystNoNoNo
Evap SystemNoYesYes
Secondary Air SystemNoYesYes
AC RefrigerantNoNoNo
Oxygen SensorNoYesYes
Oxygen Sensor HeaterNoYesYes
EGR SystemNoYesYes
MIL Off
Number of Confirmed Codes: 0
Readiness Standard: None
This vehicle is ready for emissions testing.
Trouble Code Report​
ECUCodeTypeStatusDescription
ABS/VSC/TRACC1201ChassisConfirmedEngine Control System Malfunction
ABS/VSC/TRACC1422ChassisConfirmedMaster Cylinder Pressure Sensor Zero Point High
ABS/VSC/TRACC1456ChassisConfirmedControl Pressure Sensor Zero Point High
ABS/VSC/TRACC1201ChassisHistoricalEngine Control System Malfunction
ABS/VSC/TRACC1422ChassisHistoricalMaster Cylinder Pressure Sensor Zero Point High
ABS/VSC/TRACC1456ChassisHistoricalControl Pressure Sensor Zero Point High
Cruise ControlP0504PowerTrainConfirmedBrake Switch "A"/"B" Correlation
Cruise ControlP0504PowerTrainHistoricalBrake Switch "A"/"B" Correlation
Additional Information​
PIDDescriptionValueUnits
SAE 0x21Distance traveled while MIL is activated0miles
SAE 0x4DEngine run time run while MIL is activated0min
SAE 0x30Number of warm-ups since DTCs cleared24
SAE 0x31Distance traveled since DTCs cleared166.53miles
SAE 0x4EEngine run time since DTCs cleared1589min
Thanks for the response, super helpful. Seems like I need to start by checking light operations for P0504 and C1422.
C1201 is the one that kind of scares me.
I will look into other adapters to see if I can find something more compatible. I did make my way over to Costco and got the nitrogen topped off in all 4 wheels.
Is it odd that the check engine light is not on with the C1201 code?
Did codes come back after erasing them?
Not all codes will turn on CEL but 1201 I would think it would.
Is it showing up in live or historical codes?
it did show back up after resetting, and all four codes are appearing as confirmed and historical.
Maybe worth adding - the car did just pass a NY inspection a week ago.
