New to me 2010 GX460 with 130k. I purchased the GX last week, everything feels tight on it, runs well, everything works, interior and exterior are in good shape (excellent for a car that has lived its life in Brooklyn).
I picked up a BT OBD2 adapter which was delivered yesterday (LeLink OBD2 Diagnostic Tool) and using OBD Fusion with the $10 Toyota add-on.
C1201 - Engine Control System Malfunction
C1422 - Master Cylinder Pressure Sensor Zero Point High
C1456 - Control Pressure Sensor Zero Point High
P0504 - Brake Switch "A"/"B" Correlation
OBD2 equipped cars are new to me, so this is my first time dealing with codes.
A little research suggests that the P0504 issue is probably just a problem with the break indicator switch which is easy enough to diagnose and fix.
I found some information suggesting that it is possible the C1422 and C1456 codes may be remedies with a Zero Point Calibration (if I am lucky?)
The C1201 is obviously the concerning code.
I have not been able to get the OBD2 scanner to read information from the tire pressure management system. Not sure if its just my BT adapter or something else.
There are no dash lights on, no check engine light or other warning.
If anyone could suggest next steps to diagnosing the issues that would be super helpful. Thanks all.
Here is the top part of the report exported:
VIN: JTJJM7FX2A5014473
Manufacturer: Lexus
Model: GX460
Option: 4.6 L
Year: 2010
MIL Off
Number of Confirmed Codes: 0
Readiness Standard: None
This vehicle is ready for emissions testing.
Diagnostic Report
Manufacturer: Lexus
Model: GX460
Option: 4.6 L
Year: 2010
Monitor Status Report
| Name | Continuous | Available | Complete |
| Misfire | Yes | Yes | Yes |
| Fuel System | Yes | Yes | Yes |
| Components | Yes | Yes | Yes |
| Catalyst | No | Yes | Yes |
| Heated Catalyst | No | No | No |
| Evap System | No | Yes | Yes |
| Secondary Air System | No | Yes | Yes |
| AC Refrigerant | No | No | No |
| Oxygen Sensor | No | Yes | Yes |
| Oxygen Sensor Heater | No | Yes | Yes |
| EGR System | No | Yes | Yes |
Trouble Code Report
| ECU | Code | Type | Status | Description |
| ABS/VSC/TRAC | C1201 | Chassis | Confirmed | Engine Control System Malfunction |
| ABS/VSC/TRAC | C1422 | Chassis | Confirmed | Master Cylinder Pressure Sensor Zero Point High |
| ABS/VSC/TRAC | C1456 | Chassis | Confirmed | Control Pressure Sensor Zero Point High |
| ABS/VSC/TRAC | C1201 | Chassis | Historical | Engine Control System Malfunction |
| ABS/VSC/TRAC | C1422 | Chassis | Historical | Master Cylinder Pressure Sensor Zero Point High |
| ABS/VSC/TRAC | C1456 | Chassis | Historical | Control Pressure Sensor Zero Point High |
| Cruise Control | P0504 | PowerTrain | Confirmed | Brake Switch "A"/"B" Correlation |
| Cruise Control | P0504 | PowerTrain | Historical | Brake Switch "A"/"B" Correlation |
Additional Information
| PID | Description | Value | Units |
| SAE 0x21 | Distance traveled while MIL is activated | 0 | miles |
| SAE 0x4D | Engine run time run while MIL is activated | 0 | min |
| SAE 0x30 | Number of warm-ups since DTCs cleared | 24 | |
| SAE 0x31 | Distance traveled since DTCs cleared | 166.53 | miles |
| SAE 0x4E | Engine run time since DTCs cleared | 1589 | min |
