A/C System error code 97
Jackson tn
I don't have anything wrong with the AC or Heat other than none of my settings save, and every time i get in the GX the temp is set back to 75. When I run the A/C diagnostics 97 displays on climate control. Any of you run into the 97 error code before?
as usual thanks to @Acrad
I know what the error code stands for , just wondering if anyone had the same experience .
I’ve tested all servos . They all work fine . What I’m thinking is that the AC amplifier harness connector (5 pin) is corroded. The harness connector has a chip inside and they are known to get moisture and corrode. I haven’t taken the glove box out to test my theory.
