Hi everyone, I have been lurking on here for a while, and finally have a project worthy of starting a thread. I plan to join the VICruisers club once I have a cruiser that will make it down from Nanaimo for a meeting...
I got a bj60 about a year ago and have driven and 4x4ed it since. It has the typical rust (frame almost broken in half...), and has had a few close encounters with trees since I got it. Because of this I started looking for a better body to put the running gear into, which I found down in Washington about a month ago and picked up last week.
The new body is a 2 owner 85 fj60 that is is nice shape except for a bit of faded paint and a blown 2h. It is almost totally rust free, with a little spot behind the drivers rear wheel and some on the drivers door. It also came with a new set of 31 bfg ats, which is a nice bonus.
The donor bj60 has 410k, a 3b that runs nicely, 410 gears, 255/85r16 toyo mts. I am still undecided on if I will swap the bigger tires and lower gears over.
My plans for the swap are:
-Do a bit of work on the bj engine, tranny and tcase including cam bearings, seals, clutch, tcase rebuild
-Swap in the bj wiring harness
-Paint the frame, etc and seal off the holes in the frame that allow dirt in
-Retain the AC system - I will have to source are build a bracket for the compressor
-Get it back on the road asap - hoping to be able to drive it this summer
If anyone has any advice on the process let me know. I am planning to document it here, as I have not documented my previous projects and wish I had.
Any questions on importing, etc I can answer as well. It was a very simple process.
BJ60:
New FJ60
The worst of the rust:
So far I have had one day to work on it, and I have the front clip removed and the motor nearly out of the FJ. I am hoping to finish pulling the engine this weekend and start pulling out the wiring harness.
BJ60:
New FJ60
