NEW HOW-TO TECH: 80 Series Aluminum Roof Rack
Here are few shots of SWCruiser's :princess:
I like how low profile it is and with 10 mounts should hold up well if it ends up on its lid :D.
One thing I want to try is mounting a front fairing (like a Thule or Yakima) to try and retain what dismal mpg I have now.
IBCRUSN,
Thanks for posting the pics.
I actually took a hammer to the front of the rack to bend those ends down. I plan on drilling holes to add a fairing when I get some time. Surprisingly, I don't hear the rack at highway speeds with the sunroof closed. Yeah, opening it up is a different story. Some of you will probably notice the mounts in the pics are not secured on this photo as it was during install. I can actually lower the rack another 3/4" and might do so when I get back to AZ. I am all about the low profile streamlined look.
No worries.
I have no idea why the one pics went in as an attachment, the other three are on my pic acct.
Once I finish both of my boxes the rack is the next project. A major bonus was the free rack I ran over this past weekend. It's a little smaller that the one Johnny mentions but free is always good.
FZJFillmore: Any idea as to where I can pick up ARB clamps? I sent ARB an email about this, but haven't got a response from them yet.
IBCRUSN: The later year JDM 61s have high roofs, see the attached picture.
Yoats, The ladder...why not attach it to the moose ramp with a hinge and have it come down the side of the rig? The weight could rest on the tire if the bottom were angled. Think of the Little Giant Ladders and the articulating ladders.
sweet$$$$ save.... im building one to put on my 100 with AO load bars
what a good plan :clap:
my wife is so happy im not spendind another 1000 bucks on the cruiser.
it was old and deep . but hell what a cool plan :clap:
I orderd my ramp last nigt .when it gets here im going to start bulding that thing.:wrench:
So is there any way to adapt Yakima type adapters to the moose rack? This thing is amazing, nice work!
I have made two of these roof racks. At least I used the concept, but made a few tweaks to serve my purposes for two different variations on the idea.
The beauty of the idea, is a simple, cheap, strong, versatile deck. I see no reason that deck could not be fastened to the cross bars of a conventional rain gutter mounted system. I will post pics of the roof racks i made from ATV loading ramps in the a.m.
Note sure this collection of pic's really do justice to the racks. The 80's rack was completed several years ago, has carried canoes, RTT, fuel, lumber, whatever. It is quiet on the freeway, and has been drug through tight ATV trails.
The 40's rack was just completed a few weeks ago.
Some variations from the original concept.
1. I wrapped the square deck in 3" x 1/8 strip rather than 2". This is 1" wider than the rack platform, and provides a 1" rim to hold on fuel cans, boxes, etc (I lay 2 x 4's on the deck for lumber & canoes that overhang the deck and would crumple the lip)
2. I elected to tack weld the deck to 1/4 AL "L" stock for the cross peices between the rain gutter towers
3. Even with a tri-fold ,XL deck, the 40 needed additional "spacers" to make the deck wide enough. I lucked out and they were surplusing a AL server rack at work, so I tacked them in to widen the ATV rack. (now I have some threaded holes for eye bolts, or permanently attaching boxes)
4. Originally my "light bar" hoop on the front of the 80, was conceived as a crumple zone, and is all "bolt on". I cannot recall how the original section was done, but I bent AL "L" stock. Later I added and AL air dam.
5. I removed the hinge pins to release the ATV ramp sections, but left the hinges on the outside of the 80's rack. I figured they would be usefull as additional tie down points. (in retrospect I would not do that again, and did remove the hinges completely when building the 40's rack)
Even though I made the 40's rack second, it probably is more poorly conceived. Note that the rain gutter pillars are "evenly spaced". I should have measured in 6" or a foot from the back for the rear one, in from the front for the front one, and the third still centered. This error, means that in theory I could put a row of fuel cans on the rear, and actually have upword pressure on the front. The front and rear rain gutter pillars should have been moved out closer to the front and rear.
slowLC: I think of this as two seperate projects; 1 the deck, and 2. the rain gutter clamps.
The beauty of this idea is largely just the deck, there is nothing new or magic about the concepts discussed in this thread regarding the rain gutter clamps. If you already have a pair of Yakima rain gutter clamps and cross rails, I would just go down to the local hardware store and get some U bolts with a strap accross the open end of the U bolt, and strap the deck to the cross rails. you may consider getting another set ( or more) of clamps/cross rails to distribute the weight. However you decide to strap the deck to the cross rails, keep in mind that the primary forces to consider are lateral forces (rack sliding side to side, and sliding front to back) as you corner with a load, and as branches rake your rack & gear on the trail. (or driving into a parking garage with the RTT still on !!!)
MickeyT, Not sure what parts you are looking for. The best price for the ATV loading ramps for me, was the local Sportsman Warehouse. In the L48 you should have more options. I got pop rivets and bolts from the hardware store, and AL 3" strip from a local supplier. I gave the local steel fab shop the bend dimentions for the rain gutter risers, and where I wanted the 1/4 black pipe welded, and they charged me a hour at the shop rate and gave me the scrap 1/4 steel for nothing. I used my angle grinder to cut the rain gutter risers out of the strip of bent steel they gave me back. I slit some fuel line hose to slip on the bottom of the rain gutter clamps to give some rubber "padding" in the rain gutter. I encased the bottom of the rain gutter risers, and the clamp, in rubber tool dip, to further added protection for the paint. the "J" bolts I also got at the local ACE hardware store.
slowLC:
;) +1
Happy to see folks are still using this idea! I still have my original one and it's through a lot with no issues. :cheers:
So where have you taken your home made roof rack? Here we are at the "Magic bus" from the "into the wild movie"
Very jealous of that picture. I would love to go see the Magic Bus.
I have a quick question for WildYoats. How did you wire the lights down without any leaking problems?
I ran the wiring along the inside of the rack, and down into the door jamb of the driver's side rear door (in a harness).
John
