To cure the smoke smell, buy some cheap Vodka put it in a spray bottle, spray the truck down, soft surfaces primarily. Close it up and let it sit a couple days and then open it all up and let it sit a couple more. Should help the smell issue.
Did you pull the carpets and pressure wash them? I had great luck for stains with my carpet set and odor with a friends. Pulled. Pressure washed. Sprinkled with oxi clean, scrub brush into the nap, let sit then pressure wash rinse and hang to dry.
Just a word on the wd 40. It wont do anything for rust except maybe make it worse. As a sinple solvent (kerosene) with fragrance and propellant It will strip any oils and dissipate water but not offer any protection. Depending on the area in need look into por-15 like rust inhibitors or fluid film wax covering
Jason, any experience with pressure washing the cloth upholstery once removed from the seats of a 60 or 62? I have heard of it done but am fearful that the stream would damage the fabric in the process......
I did this on my previous 60 but i put it in the washer inside a pilow case. They came out nice and clean.Jason, any experience with pressure washing the cloth upholstery once removed from the seats of a 60 or 62? I have heard of it done but am fearful that the stream would damage the fabric in the process......
Thanks for the tip! Do you brush in the solution and vacuum out with upholstery attachment on carpet cleaner? Apologies for all the typos, I don't know how these kids type on these phones so well.
Also success with hood latch, ot finally closes. Actually got to drive it a mile to the gas station. So she definitely missing on a cylinder it feels like. There is hesitation in the first gears when it is most noticeable then you hear/feel it missing in high gears. CEL remains on and blinks when accelerating. The PO put a new distributer on trying to fix the problem with no luck. Anyone have any ideas? It's puttering hesitation. Input some premom in to replace the bad gas that's been sitting in the tank for a year also.
Ok great, will do. Thanks again Rice.I don't do any type of scrubbing with the hair developer (I.e. Peroxide). It is a bleaching agent (thus the need to test for color fastness) so I just spay it on, let it soak, then vacuum up.
Hopefully this works for posting the image. Sorry for delay, traveling for work a ton.
I've only gotten to clean out PO junk from interior and clean out trim. I also cleaned engine bay a little.
Still not street legal. And I drove out all the bad gas and filled up with premium fuel to clean system out a little. Still runs rough, and am thinking it it is the ecu wiring that needs patching.
