New Gx 470
Ogden Utah
I just bought at 2006 GX 470. It has the air suspension. I’m trying to plan out what to do I want a 2” lift on it for some off roading. Nothing to crazy but I want to be able to go where I want to go.
Can I keep the air and just add a 2” kit or do I need to redo it all?
Should I just redo it all with the potential that the air system goes bad?
As I’m sure everyone says this money is tight so I am also looking for my cheaper options. I plan on putting on bigger tires not sure what yet but nothing to crazy because it will still be a daily driver.
Thanks for any suggestions and help.
It’s better if you can do it all at once, but you don’t have to.
You can start with the front by replacing with new shocks and coils.
You can lower the rear air sensors about 1/4” to raise the rear air bags about 0.75”.
Here’s a thread that explains some of what you want:
I’m running a 2” lift up front with Bilstein 6112s and 600 lbs/in coils. I have no extra weight up front.
The rear still has the air bags raised about 3/4”. Rear has OME 60004S shocks but seem a little stiff. I’m holding off on rear coils until I get tired of the rear air bags. The rear air bags were replaced in 2013 by PO with oem so they are relatively newer compared to 2003 ones for my model year.
Ride in rear feels jarring and bouncy when empty. Much better when loaded with gear.
In terms of tires, if you go bigger than 32.1” tall and 10.4” wide, you will need to do several modifications.
The 255/75R17s fit perfectly and are great for exploration, but a lot of people don’t like skinny tall tires and want fatter and taller 33s which will require many mods.
Thank you very much this is exactly what I have been looking for
Here’s some pictures of the new ride.
Nice and stock!
