So I just bought a 1987 FJ60 off craigslist for 800 bucks. It has 224,00 miles and it is running just fine. The guy I bought it from was the original owner and has all the maintenance records. It has been sitting since last december and it has a few rust spots from rock chips on the hood, and the brush guard was bent way bad on one side, but there is no body damage at all. I already changed the oil/filter and also the fuel filter. I also bent the brush guard back and welded it just because it looked retarded. My question is, what do you suggest I do just as kind of a quick tune-up since it has been sitting for so long. I was thinking just change the transmission fluid, differential fluid, and see what happens from there. I put an additive in the fuel that supposedly cleans out the carb. I took it on the freeway and have put about 200 miles on it just to get all the old fuel out of its system. I ordered new leaf springs and shackles and am also going to do a body lift and put new tires on it whenever the parts come. The fuel pump also leaks so I am putting a new one on tomorrow.
One thing I am not sure about, seeing as how I am new to Cruisers, the brakes are making this clunking sound and I don't know if it is normal. When I take the tires off the ground they feel a little loose like I can jiggle them. As I am driving down the road slowly I can hear the clicking sound, and when I apply brakes, it stops. Has anyone else encountered this? It looks like there is a leak around the transmission somewhere. Also, is there anything else you suggest I do just as kind of a regular maintenance kind of thing? I was planning on doing the above mentioned, taking it out to the desert and seeing what breaks/needs to be fixed.
Whatever comment you have is greatly appreciated. Thanks!
Official Mud salute.
