Get a Haynes Manual for it.
Get a good grease gun, and use it. Steering knuckles, tie rod ends, center arm, and driveshafts. Adjust the drag link and center arm.
Get a bigger pan to catch the oil for your oil changes, it holds 7 quarts. If you really like a hazmat mess, use one of the oil drain pans you get at autozone. Use good, heavy oil, like 20-50.
Strap, Hi-lift as stated before. Do not use crappy WalMart straps with a metal hook on it, they can kill you. Your truck is VERY heavy, and needs a better strap. Closed looped end strap.
Decent set of tires.
When you start to build it, and you will, get a winch before a locker, if you decide to go that route. A locker can get you further into trouble. A winch will get you out.
Option B. is to con a hunting friend into the idea that HIS truck needs a winch.
Get your pictures up, and good luck.
