So, during the week my grandson and I drove down to fellow club member Brian Brightbill's garage in Palmyra and picked up a front axle and a rear axle housing. I needed a more modern front axle to do the front disc conversion. The older (original in the 45) front axles have the old ball and claw setup instead of birfields and are not amenable to doing disc brakes. So yesterday I pulled the old front axle housing out from under the truck, was pleasantly surprised that the nuts on all four U-bolts cooperated and allow me to re-use the U-bolts. Stripped down Brian's 73 drum brake axle and slipped the hosuing under the front of the 45. Right now it is loosely attached with the U-bolts needing final tightening. I have all the donor parts for the disc brake setup from a 62 axle cleaned and ready to go. With any luck I'm hoping that the front discs are in place before the end of the day tomorrow.
Also been modernizing the hydraulics for the brke system. Tossed the original brake master cylinder and bolted on an adapter from Mark's Offorad, enables the new brake booster to clear (barely) the stiffening rib on the older firewals. had to make up an extension for the brake pedal pushrod and that is now fabbed and in place. I'm using a booster from a 73 FJ40, they're the most narrow available and I was able to source a rebuilt one from Mark's Offroad. He's great to deal with by the way. Using a master from an FJ60, it leaves plenty of room for the carburetor and original air cleaner. Once the front axle is done I need to bend and install all new brake lines and bleed the system. Also need to pop a tee into the vacuum line for the transfer case to get vacuum to the new booster. Minor item.
Had to remove the orignal oil filter assembly to make room for the brake booster. replaced it with a remote bracket that I'd had here for years. uses a PH8 Fram or Toyota screw-on filter. It's in place on the driver side fender and piped in with hydraic hoses.
Pulled the manifolds off last week, too. The flange on the exhaust pipe had been secured to the exhaust manifold with one stud and nut and a pair of rusty vise grips! was like that whe the previous owner bought it in 2005, imagine! I broke off the existing stud and drilled both of them out and now the exhaust flange attaches to the manifold with nuts and bolts. It works fine. The three piece gasket was interesting to work with, I could have used four hands to keep everything aligned while starting the bolts. It all worked out well. I was thankful that Specter had the right manifold gasket as it is NLA from Toyota.
Hopeing my rebuilt carb is in today's mail so i can fire the old girl up. i did have it running but none of the three carbs i had here worked without leaking. I'm looking forward to being able to drive it with brakes and a functional carb! Will get some more pictures tomorrow.
