Need to tap into the ONSC wisdom
Durham, NC
I'm in the middle of swapping an LS into my FJ62. The donor engine is an LM7 from a 2006 Yukon. There's some differences with this engine vs early LS IIIs (e.g,. return-less fuel rail, hydroboost PS pump, different bolt pattern for the oil pan, etc.)
My question is about the vacuum ports, though. I know there's one at the back of the engine for the brake booster. BUT, there's another about midway on the passenger side of the intake. Traditionally, you can break off a plastic tab and voila - you have a vacuum port nipple. With my engine, though, there's no plastic nipple - just a steel block off plug. I need to know the size of that plug so I can buy a fitting. This will power my xfer case vacuum system. 1/4 in is too small; 3/8 seems too big.
Any guesses on size?
Tapping plastic is asking for trouble imo.
Like fourtrax says, npt ports are measured in through hole size, not thread size. Some common npt sizes:
1/8npt, 27tpi, 21/64 drill size
1/4npt, 18tpi, 27/64 drill size
Etc...
3/8 18 9/16
1/2 14 11 /16
FWIW, the hole was tapped already (maybe from the factory). I fully intended to just snap off the plastic tab and go. Then I found a steel plug rather than a plastic tab. I did try 1/4 NPT and it was too small. I have a 3/8 vacuum port, but I can see with my naked eye that it's slightly bigger than the plug. Wasn't sure if there was an in-between size. I'll post some pics tomorrow.
Some pics in case they're helpful...
