Wanted Need to find rear shock brackets (upper shock mounts)
Seattleish
So I got the new 80 project up on the lift the other day to take stock of its overall condition underneath. What quickly disturbed me is there are no rear shock brackets (used to mount the upper end of the shock) on either side. The shocks were just shoved through the hole where the brackets would mount, and apparently just float there. Not ideal, so I’m wondering if anyone knows if/where I can acquire those. The LPS was of course clueless. Thanks.
@roadstr6 might know, he just swapped axles.
Paging @arcteryx
This is exactly in his wheelhouse.
Talk dirty to him & he'll probably even give you his (shock plate) nuts. ;)
Here are the part numbers... well minus the knock sensor
Awesome, thanks for the info. I called the local stealership and after much explaining, then being transferred to “Jeff, the old school truck guy” they were able to source me a set. Good to know obscure pieces like these are still available for our rigs.
I have a set I just removed and should fit in a small flat rate box. Pm me if interested
