Need the rear panhard rod torque specs.
Jackson Tn
So im in the middle of doing airbag instalation on a 2013 cruiser. And im ready to torque the bolts and nuts
so far ive found that the following require
Wheel 97 ft lbs
rear Sway nut connected to KDSS 74 ft lbs
rear Shocks 72 ft lbs
Rear sway bar small nuts 22 ft lbs
For the life i cannot find the panhard rod torque specs, ive been searching for the last hour, and I can find for other vehicles but the lc200
111. Same as the suspension links on the rear axle. Make sure you do all this at ride height.
