]Hi all![/SIZE]
I am running a SB 350 engine connected to an SM465 Chevy transmission which in turn is connected the old style Toyota transfer case through an Advance Adapters adapter. These are in a 1968 FJ40. I recently pulled the transmission and transfer case to replace a leaking front seal on the transmission and the front seal on the transfer case. I replaced the clutch fork(cast iron with cast iron), clutch fork pivot ball, throwout bearing retainer, clutch(12” LUK with 12”LUK), and throwout bearing. When I got it all back together, the transmission would not shift. When the pedal is depressed the disk is still held tight between the pressure plate and the flywheel. I thought that I was not getting enough throw from the slave cylinder—slave piston was not traveling the full length of the cylinder bore. Now it had been shifting ok before I pulled the transmission. I adjusted the rods on the master and on the slave and bled the system with no improvement. I then read on the main forum to use a brake master cylinder to get more volume of fluid. I tried that and the piston is now coming half of its length out of the cylinder. The clutch disk still appears to be tight. So I am looking for suggestions on what to try next. I am ready to pull everything back out—except that I am not sure what to look for when I get it apart. Maybe its time to spring for Centerforce type of clutch? Thanks!
