We have a 350 Fuel-injected Ramjet in front of an h55f five speed with about 135 miles on it.
Fuel pressure varies between 35 and 40 psi at both idle and higher rpm, but with gauge on manifold under the hood, we cannot tell what fuel pressure is while driving.
We are experiencing intermittant but persistant bump to a high rpm (2,000 to 2,200 rpm) when lugging or putting a load on the motor while in gear at a low rpm. Stated otherways, we see this rpm bump to 2,000 rpm, without footpedal input, intermttantly in 2nd, 3rd, & 4th gear when we lugg it (at about 800 to 1,200 rpm.)
It feels as if the computer is forcing the bump in rpm and is a bit unsettling to have the rpm increase with no footpedal input.
Any ideas?
Another problem, also intermittant, is at idle-down when coming to a stop, foot off gas and with clutch pedal in (disengaged), the motor will occasionally idle down well below the 750-800 rpm range and almost, almost die, then recover to normal idle.
Again, any ideas.
Thanks
Any ideas?
Again, any ideas.
Thanks
