and a triple post...
Semantics...in a literal sense, I am correct, in a non literal sense, you are correct.
Thank you. I made sure to put the mechanical slider in the same position as the one I removed, and that probably was hat he was referring to.As I remember, the only electrical component in the system are the fan controls. The rear fan switch is a rocker that I didn’t disable and front has worked great since I bypassed rear. Could also be the mechanical cold/hot slider on your new valve needs to be all the way one way to maximize coolant flow, if that can be considered a switch. I can’t think of what else they might be referring to.
