I'll second CaptainKirk... Those knuckles are eerily crust free. Check your gear oil level in the diff and pump some grease in those knuckles thru the square fitting in the top.
Also regarding the stealership prices, talked to service guy at stealership, he quoted me at 480 for front brake pads and rotors. didn't know what birfields were.
Wow you actually lost the backing plate of the pad and ground up the piston and rotor. I guess you have a rear caliper, pads and rotors to buy know.
I have always bought rotors as a pair. Is this really necessary?
I would either buy a new pair of calipers (or remans) or buy one reman and rebuild the other. You do not want to run a new/reman and an old one, and I would not run mismatched calipers (OEM and aftermarket).
Same for the rotors.
That's the advice I was given by Mr. Cdan when I went through something very similar a few years back.
I agree on having matched components (calipers/pads/rotors) on both sides, but unless there is damage to the caliper body it should be pretty easy to rebuild both rears. Every other part, including the piston, is available. A rebuild kit and two new pistons wouldn't be much more than $50 and a couple hours.
think reman and pistons are available at shops? everywhere, including stealership, had to order calipers. napa had to order from atlanta and said it'd be 6 business days
I think I recall you thinking Dan might be avoiding you but I seriously doubt that...He just tends to be REALLY busy all the time.
Obviously there is no guarantee that CDan will have what you need in stock but I think your chances are greater with him than just about anyone else. Unfortunately you are going to be having some heavy items shipped which could get pricey if you can't find what you need locally...
