ok. It seemed the scraping of the brakes was not consistent--it is. I was at a drive thru and I felt the lack of stopping, the brake pedal almost to the floor (but not fully). So from there I decided I needed to just drive this baby home--with hazards on. Every time I applied the brakes bad scraping and grinding sounds came. When I'm begining to accelerate (say from 0-8 mph and no brakes are involved) there's still a metal scraping sound, but much softer and quieter. On the way back (after the drive thru) I caught the tail end of a yellow light, as I was going around the turn, tapping the brakes to see if stopping was even an option, there was loud scraping and grinding but it seems like the brakes were lost and it would cause serious damage if I were to slam on the brakes if i needed to stop the rig. It's my DD, but I drive a lot for work. I make my own schedule, so I can take a day or two off if its best for the rig. Its my DD but I drive the hell out of it too... I would've been at the offroading park with it today if I had convinced myself my brakes were so bad. I've had it for right about 3 and 1/2 weeks and have put about 2k miles on it and have taken it offroading prob about 10-12 times/days.
OK, you're past the point of just slipping in some new pads.
I agree with lacruiser, but I'll take it a step further.
You're likely past the point of just slipping in some new pads and new rotors.
When you apply your brakes and let up, the master cylinder retracts and literally sucks brake fluid back into it. This is a hydraulic action that causes the calipers to retract, and pull away from the rotors.
But even pulling the pads away the brake pads will lightly touch (or be very very close to) the rotor. This is why if you look at your brake fluid and see that it reads "low" you don't just top it off. You either have worn pads--meaning that the pistons are riding further extended in order to be close to the calipers, or you're losing brake fluid somehow (IE: leaking soft line). It doesn't just disappear or get "used up." The system is designed so that you have an idea of when your pads are done.
Anyway, the grinding sound you hear is (and this is just my best 630 mile away guess) is the brake pistons riding on the rotors. Because the pistons don't fully retract they will lightly ride the rotor, and you'll hear a grinding.
There are all sorts of sounds you can hear from brake pads, screeching, pulsating/grabbing feeling, but grinding is not one that you should hear. That grinding is metal to metal contact, and unless something funky is going on that usually means piston to rotor.
As far as cost goes, it depends on front or rear and how bad the damage is. The front rotors on my truck are lightly scored due to a frozen piston, it stops just fine (even comparing it to the
truck). But it's very very light scoring, and I replaced both the calipers and pads with new, and I caught the problem
before it was metal on metal (and still didn't avoid slight damage to the rotor).
You are going to spend a lot of money, so I highly recommend going through Cdan if at all possible. I highly doubt that anyone local will come anywhere close to his prices. Still expect to spend $500+ if you need rotors, calipers, and pads. I don't remember the exact prices on mine, but it wasn't cheap.
As far as OEM vs after market goes, I wouldn't use any of the aftermarket stuff personally. When the
truck had a brake pad snap in half (literally) and slide out of the caliper (which resulted in metal on metal contact between the piston and rotor) I priced out after market calipers at Les Schwab. The price was nearly as much as Cdan (though theirs was parts + labor vs just parts) and the caliper they wanted to use was nearly half the size of the OEM one. The size difference was just silly.
So I've not been impressed with most aftermarket stuff out there when it comes to the braking system. I'm sure there's decent stuff out there, but the OEM setup frankly flat out amazes me and has far exceeded my expectations in every situation I've thrown at it.
Anyway, any way you cut it you
need to pull off the wheel and see what is going on in there, for all four of 'em (front and rear). Take pictures and post up here if you are unsure as to what you are looking for. You don't even need to pull the calipers off, just take a picture of the caliper from the edge on (like you are taking a picture of the edge of the rotor, but with the caliper in the way) and we should be able to see how thick the pads are. Make sure you get a good pic of the rotor's surface as well. Shouldn't take long to do, just jack up the truck, throw jackstands under it, pull the wheel, take pictures, pop wheel back on, lather, rinse, repeat.
