Hi guys.
I need some help.
I used to own 100 series long time ago. I now own GX470. The rear axle are known to be weak and I am researching some affordable alternative. I found 100 series rear axle are cheap and can be had with locker and 4.30 ratio. I am already running 4.30 in my truck. So if I can make this work it would a really awesome cheap upgrade.
I know this axle are a lot wider than my GX axle. But with the strange combination of OEM 60 mm wheels and 2" wheel adapter up front it actually would be the same as running aftermarket wheels with +10 offset.
I need to know the dimensions marked in 3 red arrows in the picture below.
I know the bushing for the link arm are different, the lower on the GX are the same as the upper and the bottom are a bit bigger. I am OK with making custom rear link. It should be easy to fabricate.
I also need to figure out the rear ABS sensor if anybody know the number of the tone ring teeth count. I wanted to keep ATRAC function. The sensor are totally different. I need to keep GX stye. Pic below.
If any body can post a picture of the rear speed sensor location, it would be greatly appreciated.
Thank you very much.
I need some help.
