Need help with interior led lights
Can anyone point me to someone/someplace that could convert my 2000 LC interior lights to LED? I probably could figure out the cabin lights but have no clue about the dash lights. Don't have the talent, but have the $$$
I'm in San Diego area
Thanks
Gary
Pfran LEDs sells a package of dome and other interior lights. Check the vendor forum for his info.
You'll have to search a bit for dash light details. There were posts as recently as yesterday on the topic.
You can order the kit from Pfran, and read on here how to do it. It takes less than an hour with only the most very basic of hand tools required.
This was my extensive list for doing the gauge cluster, hvac, and all the lights by the shifter/heated seats what and what not.
The red 4mm is for the hazard light!
I ordered off of super bright LEDs
PRODUCT(S)
QtyProduct/OptionsPrice/Ea
974-xHP3: 74 LED Bulb - 3 SMD LED Wide Angle Wedge Base 74-CWHP3: Cool White$3.49
1NEOx-xHP: NEOx LED Bulb - High Power Instrument Panel LED NEO4-RHP: 4mm NEO4-xHP Red$2.29
8NEOx-xHP: NEOx LED Bulb - High Power Instrument Panel LED NEO4-WHP: 4mm NEO4-xHP Cool White$2.29
2NEOx-x: NEOx LED Bulb - Instrument Panel LED NEO5-W: 5mm NEO5-x Cool White$1.29
5NEOx-x: NEOx LED Bulb - Instrument Panel LED NEO3-W: 3mm NEO3-x Cool White
Let me know if you need interpretation
Sent from my iPhone, please embrace the typos
There are a couple threads on how to do the dash lights yourself. It's so easy even I can do it! And I did for the HVAC lights, gonna wait a bit before I do the speedo/tach cluster only because I'm too lazy to do it right now.
Thanks guys for the help..... I'll try to find the best post on how to change the light out... You have to pop the dash off???
I'll give it a go and hope I don't f it up! Lol
Thanks Chris
I'll check it out.... The dash looks pretty hard to take apart, hate to break something
Does anyone have a complete list of led lights needed to replace every bulb on the dash, radio, heater controls and all on the console? Want to do them all at the same time to get a uniform appearance. A few don't work including the infamous D light, mirror control, antenna and side windows.
Your educated suggestions would be appreciated. May be a list on a web site I haven't found yet.
When we changed out the bulbs on my son's 2000 TLC, we made a list based on these 2 threads:
Unfortunately we didn't save the list after we placed our order.
I replaced my interior lighting with LEDs as one of my first upgrades. The LEDs are almost too bright. I only use 1 to light the interior. I've heard people complain about the brightness of the LED gauge lights. I think it would be over-powering, and unless they are dimmable (no idea), you couldn't dial down the brightness. And personally, I prefer not having the "D" light stare me in the face. YMMV.
The LEDs dim with the standard gauge dimmer.
So I recently started replacing all my dash and component lights with LED's (including heat warmers, shifter etc) as many had burnt out. Due to the polarity I tested each as they were installed to make sure they were in the correct orientation. I accidentally arc'd out one of them and I thought blew a fuse. For the life of me I (or my mechanic) can't find a burnt out fuse in any of the panels (2 kick panels and the engine fuse box). Can anyone suggest where I can look next. I know COMPLETELY dumb move but I'm hoping someone on here can help.
Someone had asked for a "consolidated" list of all LEDs in the UZJ100. From my experience updating the dash in my 2000 LC, here is my parts list, with each bulb/part number. All items were sourced from SuperBrightLEDS.com
** I had issues finding polarity for some of the dash lamps and gave up on LED. In those places I reinstalled new 74-LL incandescent bulbs.
** I also kept the D light mod, so you really only need 5 lamps for PRND2L indicator in the dash
Finally, I found it infinitely easier to remove/install the cluster by removing the steering wheel. YMMV
Here you go:
area location type qty color p/n
driver side panel R-Rear window neo3 1 cool white neo3-whp
driver side panel L-Rear window neo3 1 cool white neo3-whp
driver side panel mirror switch neo4 1 cool white neo4-whp
hvac panel hazard neo4 1 cool white neo4-whp
hvac panel diff lock neo4 1 blue neo4-bhp
hvac panel antenna neo4 1 blue neo4-bhp
hvac panel clock neo5 2 blue neo5-bhp
hvac panel hvac neo4 5 blue neo4-bhp
hvac panel glove box 74 1 cool white 74-CWHP3
ignition ring ring light 74 1 blue 74-bhp
dash cluster brake 74 1 white 74-LL
dash cluster door 74 1 white 74-LL
dash cluster airbag 74 1 white 74-LL
dash cluster vsc off 74 1 white 74-LL
dash cluster vsc trac 74 1 white 74-LL
dash cluster skid 74 1 white 74-LL
dash cluster diff lock 74 1 white 74-LL
dash cluster active track 74 1 white 74-LL
dash cluster cruise 74 1 white 74-LL
dash cluster at/p 74 1 white 74-LL
dash cluster at oil temp 74 1 white 74-LL
dash cluster chk engine 74 1 white 74-LL
dash cluster seatbelt 74 1 white 74-LL
dash cluster abs 74 1 white 74-LL
dash cluster fuel 74 1 white 74-LL
dash cluster batt 74 1 white 74-LL
dash cluster L turn 74 1 nat white 74-nwhp
dash cluster high beam 74 1 nat white 74-nwhp
dash cluster R turn 74 1 nat white 74-nwhp
dash cluster ECT neo4 1 cool white neo4-whp
dash cluster O/D Off neo4 1 cool white neo4-whp
dash cluster 2nd STRT neo4 1 cool white neo4-whp
dash cluster PRND2L neo4 6 cool white neo4-whp
dash cluster Gauge backlight 74 6 blue 74-BHP3
center console PWR/2nd neo3 1 blue neo3-bhp
center console Gear selector 74 1 blue 74-BHP3
center console R seat heat neo3 1 cool white neo3-whp
center console L seat heat neo3 1 cool white neo3-whp
Mike
