I was working on refining my desmog job in my 62 today in hopes of getting rid of more vacuum lines (got rid of a ton, but need to make sure it's not going to cause problems in the long run), and noticed that the vacuum line that goes from the fuel pressure regulator to the VSV that's mounted to the driver's side fender has long been capped off. I looked all through the EFI and fuel control sections of the FSM but can't find any description of how/when the regulator is supposed to have vacuum applied to it. Right now (actually, ever since I desmogged it five years ago) there is no vacuum going to it, but I'm wondering if it's supposed to have either manifold vacuum (which, when stock, it gets when the VSV is open), intake plenum (ie: from the throttle body) vacuum, or just no vacuum going to it like I have it now.
Any thoughts from you EFI gurus?
It wouldn't be too hard to just get the single VSV from a junk yard and wire it back in and plumb it into manifold vacuum if need be.
