Hey guys, got a bit of a problem with my 1988 HJ75!
Went and had a bit of a mid-week play at a local track and broke my truck. Was nothing particularly challenging -
In both 2WD and 4WD, if I put too much load ie take off fast or hard, this terrible grinding noise comes from the back of the engine area/gearbox area. There is no burnt clutch smell or anything. Any ideas as to why? My first idea was that the rubber spaced gearbox support with fluid in the middle of the rubber was worn on one side and when I put a large amount of torque through the GB, compressing the fluid filled (leaking) rubber and possibly reducing the contact with the flywheel and clutch?
Also, my Front wheels when engaged in 4WD both high and low range are not working. I have discovered that my pinion seal not fully sealing - could this (lack of oil/less than full) within the diff be the cause?
Other things it could be? possibly broken CV/axle?
If one hub is not engaging, would both wheels not work when in 4WD
Help would be much appreciated as this is my daily.
Thanks ahead,
Dean
Thanks ahead,
Dean
