Do you have the cowl harness that goes to ecu?
Sorry no.Do you have the cowl harness that goes to ecu?
Thanks for the reply. Happy Holidays.Sorry no.
I am also looking for these same sliders. If @kardancewine doesn't want them, I will take them.
I flaked out. all yoursI am also looking for these same sliders. If @kardancewine doesn't want them, I will take them.
thanks
Sorry, I don’t have those.Looking for the brackets that are mounted to the frame that the isolator and then engine mount attaches to. Frame mounted, above the front axle, one on the DS and one on the ps. likely riveted on. OEM part#'s are 51422-60040 and 51421-60040 (or in the frame diagram 51401 and 51402)
Apparently someone took mine of my 85 60 thinking they would do a V8 swap. I need them for the rebuilt 2F in my garage. Thanks.
Sorry I don’t have that part. Best,kbDo you have a front turn signal housing (for the bulb)?
shipping to 37069, thanks!
Joel
Yes. I have an original piece with original gray OEM carpet still attached. I’ll post link below.Do you have the board the tailgate carpet attaches to?
Sorry, I do not have that part.Do you have the fuel sending unit on the tank?
Sorry I don’t have that part.Hi. Do you have any wire harness parts? Specifically looking between combination switch on steering column to main harness in the dash/fuse box area?
