SOLD NC: 1989 brown FJ62 interior and misc engine parts electronics
Status
Not open for further replies.
OEM rear view mirror.
All prices are + shipping unless noted otherwise.
Updated: 10/1/2020
***sale take 20% off any price listed***
I need to clean out the garage
Front lower footwell corner covers: $5 each
Driver side seat adjuster price drop: $50
Glove box door (minus lock) $10
Rear 3 point seat belt complete with vinyl brown wheel arches: price drop #2: $175 shipped.
Accordion tube and connector: $30
Distributor: $120
Rear seat carpet holder metal trim: $10 set, 3pieces
Ignition cylinder + glove box cylinder with 1 matching key: $60
Complete instrument panel: $150
Rear seat upper latches: $10 each
Window regulators, right rear only: $30
Hood spring hinges: $15 each
Steering column assembly, with upper bracket, less ignition cylinder price drop : $125
Parking brake boot (torn) $5
Steering gear with pitman arm and output shaft: $350
Seatbelt warning 85991-22020: $10
Charge lamp relay 27790-13010: $20
Transmission control module O/D 89530-60020: $20
Circuit opening relay 85910-14020: $30
Radiator overflow bottle: $5
Grey front seat Belt receivers: free + shipping
Cigarette lighter connector: $5
Rear wiper switch: $5
Dash illumination section:$5
Seat belts warning light: free + shipping
Front turn signals some cracks/chips: $10 each
EGR vacuum MODULATOR: $30
Rear vertical plastic trim price drop: $20 each
Upper thermostat housing: $100
Brown door cards: price drop#2: front passenger $20, left rear $20
Coil with igniter assembly tested/working: price drop #2 $120 shipped.
Cold start injector: $100
Carb cooling fan: price drop $30
Air pump brace bar 1731861060: $10
Fan/water pump pulley 1617361070: $35
Smog pump: $150
Overflow bottle bracket: $15
Idler pulley with bracket: $30
AC compressor untested: $50
AC lines: $20 each
Fuel connector and fuel separator: $80
Grille: $75
Headlight door, right side only: $50
Front valence: $40
Interior rear view mirror: $50
MAF: sold
Alternator brackets and adj screws: sold
Gas pedal and throttle cable: sold
Rear upper hatch with glass: sold
Power antenna with new mast, reconditioned, tested and working: sold
Ash tray: sold
Rear wheel ornaments: Sold
Auto shift assembly with base and gasket (without outer most plastic bezel - already sold): sold
Radio (radio works great but cassette not working/LCD has black spots) : sold
Rear upper seat back: sold
ECU computer tested /working: sold
Fan and clutch: sold
Upper radiator support brace: sold
Center vertical hood latch brace: sold
Hood latch mechanism: sold
Steering wheel Brown: sold
Aftermarket rear view: sold
Brown fuse cover: sold
Fan shroud: sold
Rear heat switch with new sticker: sold
Chrome drip rail: sold
Driver front door card: sold
Brake switch: sold
Taillight housing with gasket: sold
Door lock actuators (4) : sold
B-pillar covers price drop: sold
Ac dash control unit: sold
Mirror switch: sold
Washer bottle: sold
Rear wiper motor: sold
Front seat belt receivers: sold
Air box minus MAF: sold
Lock cylinder driver, passenger, gas door (no rear hatch): sold
Center console: sold
Steering column clamshell: sold
Rear speaker set with grill, mesh, mounting, speaker: Sold
Rear speaker brackets: Sold
Window relay green: Sold
Indicator/wiper stalk: Sold
Ac trim plastic: sold
OEM power side mirrors: Sold
Rear vents: Sold
Visors: Sold
Rear tool access cover: sold
Left Rear speaker panel: sold
Washer access plastic cover: sold
Hey, I am very interested in the cold start injector. Do you have the bolts with it as well?
Do you still have the rear trim for the seat back on post #2 and the A pillar grab handle on post #25? shipped to 94546.
Status
