Nav CAUTION screen
Pardon if this has been asked million times before but how do we get rid of the startup Caution screen?
that's what I was suspecting as I couldn't find any information so far...
I leave mine on the trip info screen so when it starts up, I see the Toyoto logo and then it goes right into my MPG & fuel stats. Not that this helps you in any way, ha.
Nope.. don't want to be reminded of the infamous MPG all the time :)
This is the way I do it.
I have a GROM VLine I have to install yet, and I'm hoping that won't have nag screens like the Toyota nav, and can default to Android Auto display.
great. please let us know how GROM set up defaults.
One of the other cheaper BT modules does defeat that screen. Do some searching around and it will pop up.
I do what Couvi does: my truck is always set to Trip Info since I never use the factory nav.
Press the " I Agree" button and it will go away.
Upon next startup, press it again.
Repeat
JK, but lately I've just been running with my display off . I am almost positive that when I start the vehicle, it just stays blank. Unless I press map, I don't see the warning. I can press climate and get right to my settings but otherwise I don't mess with it much
Assuming you want the map view though ? Pretty sure there is no way around the safety check screen to get into the map view.
Ever actually do the math? I find these screens to be off by a few mpgs compared to calculating at the pump. Curious if you've seen the same.
No i don't want the map view at all. If I shut off the vehicle while in Climate control or any other mode and the next time I start up it automatically forces the system to go into Nav mode and hence the Caution screen.
I am actually surprised that if you shut the vehicle off while in Trip info mode, the next time you startup it stays in that mode. I think it might have been a bug from Toyota that they forgot to force it back to Nav mode from Trip mode :))
my display stays off full time after going into the settings selecting the display off option.
When I start the truck I get the toyota logo followed by a black screen. The radio station bar is on the top of the screen but then goes away to black
I can then access the climate screen and it goes back to black
Only time the caution appears is if I go over to map view
That's also a good idea though I don't want black/display off screen as default. I wish somehow we could make it default to Climate screen on every start up.
Repeat
My mpg screen is pretty accurate actually. I feel I get a pretty consistent 15.5 mpg with mixed driving. Usually 330+ miles on a tank - I drive a few more miles once the light comes on.
