I have an offset t-case and need to narrow a 14 bolt I picked up to match. If I shorten the long side axle tube to the same length as the short it will work out perfectly.
I have to find out if the tube is sleeved at the end much like the front cruiser axle. That would allow me to cut .5 into the tube pop the end off. Cut the tube down to length and slide the end back in and weld it. Thats all if the tube is sleeved.
Or I have to some how remove the tube from the 3rd, cut to length and machine it back to down to slide it back in and weld it... None of that seems fun.
Or sleeve the tube, find some DOM tubing to sleeve the inside of the axle tube. Slide it back together (after its cut to length) and weld it.
Any ideas would be cool, I have to break down the axle and see if the ends are sleeved or not.
-Al
-Al
