WHY WON'T MY LX START?
I honestly have no clue what's going on here...
Once in a while (happened 3 times now) when I go to start my truck, it just cranks and cranks but does not fire. I cannot figure out what is happening, although I have an idea or two...
Here's where this started:
Last summer at our cottage I parked my truck as usual, locked/armed the vehicle with the factory lexus keyfob. 1.5 hrs later when I went to start it, it just cranked but did not fire. I was able to walk back to our cottage and grab my other set of keys to try and I got a ride back to the truck. Tried immediately again - no luck. I then opened the hood, looked at all the plugs/wires etc, disconnected/reconnected battery and tried some various troubleshooting ideas however none of them worked. Then I played around with the locks locking and unlocking quite a number of times, and opening/closing the door in a similar fashion to someone trying to code a new key. After about 2 mins of doing this I tried again, and voila! It worked. My truck has started/ran fine (wonderful at that) for the last 3 months without issue.
Last week:
I was leaving work, and once again, the same thing happened. This time I only left the truck for no more than 5-10 mins (locked/armed as always) and when I returned, again just cranking, and no firing. I tried cranking for quite a while (being sure not to overheat starter of course) on and off, but to no avail. I tried doing the doorlock/opening/closing dance again - but this time that didn't work. I then hit the alarm button on my keyfob, then immediately disarmed it by hitting the unlock button, then went to start the vehicle, and voila! It started. Since then, we've used it regularly without problem for at least 15-20 starts I'd think. No issues.
Today:
I was at home, Vehicle was locked/armed as usual, and had been so for about 1 hr or so. I unlocked as usual, went to start, and exactly the same issue was happening again. This time I tried the door/unlock/brake pedal dance again, no worky. I tried doing the alarm/disarm thing numerous times, that also didn't work as it did the last time. I tried the other set of keys, no help. I tried the alarm over and over, no worky. Then, I tried hitting the alarm button one more time, but this time I tried to start the truck with the alarm going off - Voila! It started. What's going on with my rig? My LX otherwise runs like a dream, and the thought of replacing it with something less worthy is hard to picture, although reliability is very important to me as this is my wifey's & 3 kids main vehicle.
Facts:
- No unusual sounds or smells during any of this
- Vehicle: 1999 LX in my sig - 197k Miles
- I'm not sure if the fuel pump has ever been done - I doubt this is a fuel issue due to the way this is happening, and the truck runs super smooth otherwise.
I really think this is ignition related or something to do with the way the truck sees the sensors in each keyfob. 1 keyfob is original, one is a replacement but BOTH are masters, not spares
Secondary fact:
- My wife has always used a master key (with clickers) built into the body of the key.
- For the last 1 yr (until last week) I have been using a secondary key that was cut to fit the ignition chamber however I always had a master bank key that was coded to my ignition right next to the key I used for startup. I'm not sure if that would make any difference. The guy locally here wouldn't' cut it for me so I had it cut at a locksmith while I was in the city last week. As you can imagine, I don't head out there much, and even so, it was not a big priority of mine, but after last week's occurrence, I had this done nonetheless.
Sorry about the long thread but I figured the more info the better.... Thanks for any advice or ideas anyone can provide
Last week:
Today:
Facts:
Secondary fact:
