Vehicle: 1984 FJ60 with 1HDT / H55 transplant
I was driving merrily along, accelerating through the gears, when I noticed that when I reached 2000 rpm, my Charging System light started flashing. When I would slow to below 2000 rpm, the light would quit flashing. I got on the freeway and accelerated to approximately 65 (2000 rpm-ish), and the Charging system light started flashing again. I headed for home, and after a while, the light quit flashing, and my voltage - normally around 14 volts - dropped to 12 volts and would not move no matter have fast or slow I revved. I have two batteries, so I managed to make it home with plenty of battery left. I pulled into my garage and shut the engine off.
This all sounded very "alternatery" to me, so I pulled the alternator and had it tested; it checked out as okay. Nevertheless, fearing that it might be something intermittent in the alternator, I bought and installed a new one (only $599!
). I went to start the truck and see if the new alternator made any difference, but the truck wouldn't start. It cranked and cranked but wouldn't fire. I started trying things and found that the various Key On/Engine Off accessories would not work. I tested the glow plugs and fuel solenoid and found that neither of them were getting voltage. The radio and temperature readout also did not work, and they normally work in KOEO mode. All the Key off elements worked: headlights, ARB compressor, electric fan.
I checked all fuses, and all were good. I looked for fusable links and didn't find any. I checked all the grounds I could find and found nothing.
Again, just the Key On / Engine OFF bits are not working, and the engine cranks just fine.
I'm not an electrical-savvy sort, so I have zero idea what could be going on. Oh, and just to be safe, I changed the ignition switch as well - to no avail.
