My version of the inclinometer
Finland
I didn´t have the oem inclinometer/compass, so I made my own thing to top of the dash:
There is Boost, Pyrometer and Volts, all Auto Meter Sport-Comp series.
Thats lookin GOOOOD mate.;)
Do you have any more info on fuel pump adjustment and on how to increase the boost. I've read about putting spacers/washers in where the waste gate actuator is mounted-easy option. And to in stall a bleed off valve, but does that require some removal of parts to drill and tap?
I think you´ve read this: https://forum.ih8mud.com/90-series-tech/170126-fuel-pump-adjustment.html
I´ve also add a tuning-box, which increase the fuel amount. You can skrew the skrew about 1 turn clockwise, until it goes mad. :D Then your engine not obey to the gas pedal, revs won´t get down.
I´ve tried a bleed valve, but I didn´t like it. There was a little step when the boost goes over the normal. I don´t know what makes it, maybe my bleed valve is gone bad when it´s been unused.:confused:
A bleed valve is simple to install, if you have dexterity of fingers. Install it between the hose which goes from the turbo to the actuator. The new meter shows that my max boost is about 0.8 bar without any modifications, although it the factory boost level is 0.67 bar.
Matti, I might be selling one of the OEM clino units in the next few weeks, and I thought you might be interested.
Thanks buddy for offer, but I like my own version. :)
