Ok it's a 62 not an 80 series, but no one in the 60's section is running a turbo. I built this 3 years ago and it's been phenomenal, it's night and day better over stock. I'm running a Split Second O2 sensor enricher for fueling and that's where I'm having trouble. The Enricher is doing it's job running 11.8 - 12.5:1 under boost but the weird thing is with more pedal it gets leaner all the way up to 16:1 or even higher under heavy load and accelerating. Split Second says it's an adaption issue with the ecu and possibly also need bigger injectors. I know if I disconnect the battery and let the ecu reset it'll be better for awhile, but there's still that condition where it progressively gets leaner the more pedal I give it.
I'm running 6 lbs of boost, currently running 60 psi of fuel pressure, have an additional inline fuel pump, and running an intercooler.
So my questions are do I need bigger injectors?
Is anyone running a stand a lone system like Megasquirt?
Thanks!
Here's a short video. I'm accelerating up to 65 on the highway, you can see it's lean until I'm up to speed and let off, then there's a hill requiring more fuel and it get's lean again.
Thanks!
