Since everyone is doing trailer projects, i finally made the plunge to start my project that ive been wanting to do for a couple years now.
Most of my travels are in baja and i have towed many trailers and broken all of them at some point on a trip usually in the middle of nowhere and had various things go wrong with each trailer. Having these experiences has educated me as to what works and what doesn't. So my goal is to build a trailer that can take the abuse that baja dishes out while bouncing happily behind my 4Runner or the Cruiser.
The biggest problem ive had with other trailers is the suspension. The little 25" long leafsprings always break because they're too rigid and create a lot of heat thus breaking. Also, the little spring hangers break or bend, things are just not designed for constant off road abuse. So i wanted long leafs that flexed a little combined with a shock, and some stout hangers/hardware.
So far here are my specs:
4' wide x 7' long
The box will be 2' deep, aluminum diamond plate sides with 3/4" marine ply for floor.
Box lid - still figuring this out, but have designs for either a 1 or 2 door lid thats water tight.
Full rack out of 1x1 square tubing to mount my eezi awn above the box and hold surfboards
Frame: 2.5" x 2.5" 3/16 angle bracket for frame
Box: 1.5 x 1.5" angle bracket for corner/side/top frame supports
2" reciever pipe for tounge
3500 # axle with 6 on 5.5 hubs from abctrailerparts.com
Suspension: New 5 leaf tacoma leafsprings from wheelers offroad
Shocks - figure that out later
Wheels - 16" tacoma rims with 265's or 285's bfg at's
Spring hangers - home made.
So far the springhangers have been welded together. Now im waiting for the axle to arrive today so i can weld the frame to get the frame positioned exactly over the spring perches so the leafs are exactly lined up.
Scroll Down For Pics....
4' wide x 7' long
