Replacing the seals on either end of the box is not that hard. Replacing the seals on the pitman arm shaft is not that hard. The 'bearings are an issue only when you pull the ball bearing screw shaft out and you don't have to do that just to replace seals. All those seal kits are basically the same. The design of the saginaw boxes are the same no matter what application they come off of. Scout, Ford, GM, Jeep, all the same basic design. Some boxes do have larger pistons like the jeep box with 3.5 piston, but most all have a 3" pistons. 'Gushing' would indicate that the hard seals on the piston are shot. If that is the case, then the box itself would not be working properly which would be quite evident. Like not turning! So I would think it is only a rubber seal.
