hi guys i got a 100 series landcruiser whit a AHC on it and on the rear left side of my suspention is a bit higher then the right side of my rear suspention. any ideas on what could be the problem?
thanks
thanks
AHC system has gone into fail safe mode - it is sick. You need to read the AHC diagnostic codes, take it to a dealer, or use techstream or you can short two pins on the DLC and count the flashes. Search on here to for a PDF on AHC fault finding that describes the procedure and lists the fault code descriptions. Your problem could be any number of things; air in system, low pump output pressure, pressure sensors failed, AHC ECU failed, failed damping controller to name just a few things.and now the cars suspention is stuck on LOW...cant get it back to NORMAL or HIGH...when i start the car it tries to come up to normal but it sudenly stops and stays in LOW again and the OFF light of the suspention starts flashing.
