Builds My HDJ81 Build (4 Viewers)
20190312_204322-jpg.1932295
20190315_163503-jpg.1932329
Drooling!!!!
Excellent build.
Hopefully this weekend I will be doing some wiring. Got done with the battery tray.
This is the coiled cord I made for my Engel.
Finally finished with installing the LRA Tank. I ended up coating it with steel it. The original coating it came with had some scratches most probably happened during shipping. Took me a little time to do. For all the hardware stainless didn't want to use the ones it came with. The dual filler was also painted with steel it black. All the electrical was heat shrinked. I have a beaudeart 3" exhaust so it was a bit tight. I had a bit of trouble with the exhaust the rear flange was touching the tank. Had to do alot of exhaust support adjustment and also use a rubber mallet to bang the tank on the side of the flange. The rubber mallet worked really well. Cant even tell. Everything else went well. Works really well.
I got a great deal on this 6lb tank I found online. Pervious owner never use it and had a different vavle on it. I replaced the opd vavle and filled it up today. Also made up a plug. Now thinking of ordering a mounting bracket. Great little tank.
