My Caster Now, After Slee Arms and J Springs
Z.O.W.I.E. Headquarters
Hi all,
just thought I would share my findings after I finally had my truck aligned, but first my setup.
I have the 850 J and 863 J springs with L shocks, Slee adjustable front and rear pan hard arms, and the Slee front control arms. For static weight I have a Kaymar rear bumper with spare tire carrier and jerry can holder extensions. My truck sits pretty much level with this configuration.
Well after getting my truck on an alignment rack I found that my caster is now:
+2.9 degrees left
+3.7 degrees right
As can be seen, I have .8 degree discrepancy due to some factor but this doesn't really seem to affect steering. Seeing as the caster spec is 2-4 degrees this puts me within spec. The truck drives great! It tracks straight, is tight in turns, and generally behaves very good.
One thing I did discover is that toe can also affect steering self centering. Before I took the truck in my wheel would not automatically center in slow speed turns. Turns out I was toed out. The toe is back to spec now and centering is good.
I'm very glad I decided to buck up the cash, take Junk's quasi suggestion, and go Slee's arms.
One thing though, when I go with a new front bumper, I'm going to need to make sure that I counteract the dropping that will occur, or I just might go too positive. Of course too positive really isn't that big of problem handling wise.
I was going to ask if I could trade my '04 Taco 4WD TRD for your Cruiser but I see you already have a Taco. ;)
Hey, how do you like the Kaymar bumper? I'm familiar with it. Is the tire carrier and jerry can holder nice and strong? Does it wiggle around off road? Did it go on OK? :cheers:
Add a couple of trim packers up front to conteract the drop when you go for it.
Hehe, actually the Taco is going to be up for sale soon so I can pay off the Cruiser and other things.
I really like the Kaymar. I feel that the tire carrier and can holders are strong. The tire carrier wiggles a little while driving, but I have no rattles and am confident that the movement is fine. I haven't dragged it much but have seen one that was dragged quite a bit and it seemed to take it well.
The Slee bumper is definitely stronger, but I would only choose the Slee over the Kaymar if I was into serious rock crawling due to cost and styling. I've come to the conclusion that I like straight sheet metal too much for that kind of off-roading. ;)
