My Brakes Just Went Out
I see an awful lot of guys on here singing the praises of non OEM versions. Maybe I can spring for it but I am hot on the heels over over 4k on a manifold and exhaust so if something else will work and save me $200 I need it to. What about splitting the difference and getting the Aisin from them?
4k for manifold and exhaust????!!!
I have used remans from a number of places and never had a problem. Aisin is good but if money is tight just go with the reman. If you pull the vacuum check valve out of the booster you can use a thin zip tie about 6 inches long, as a dipstick to see if fluid has entered your booster. If the booster is dry and all four wheels are dry. Change the M/C bleed it and your back in business.
