I am done goofing around with tires and rims...sort of.
All weekend I have spent with just the beadlocks and tires. I put the firs one together with no problem. The second was a different story. First off, I bought the tires from Sam's Club and they said they would balance them, even if they had beadlock rims, I think the sales person thought they were cool and wanted to see them. So Friday night I finished the second wheel and Saturday I took them in to be balanced. When I came back with one more on Saturday night he said the darn things took a lot of weight. I knew it would, I bubble balanced the tires on another set of rims I had, the amount was pretty close to what I came up with 7.5 oz. When I took the first two home I wanted to leak test them so I pressured them up to 25 psi. The second wheel, the same one I had trouble welding, starting to making a air leak hiss. Saturday was a bust. Sunday I spent with the wife so it was a bust for the truck. This morning I finished the last two beadlocks and tires. I did not use silicone on the first three rims but after the leak was found on the second rim, I smeared it all over the welds on the last two rims. And off they went to Sam's for some more of that free balancing. When I when to picked up the last two rims the knuckle heads at Sam's put sticky weights on my rims. I told the guy that was there I wanted clip on weights, he said no one told him. I took the tires home and when I lifted them from the truck 4 of the sticky weights were laying in the bead. I did not get the tires back before they closed, this will wait until tomorrow.
I did not use the Anti-Coning (AC) stuff. When the first rim sat over night the AC ring started to move away from the O.D. of the rings. The reason must be because the AC ring material did no compress as much as the tire bead and slightly worked the opposite and created a reverse cone, allowing the AC to slip toward the I.D. of the rings. I built the tires with out it and it seems better for the tire, sort of matches the contour of the side wall.
The rear rims and tires are installed on the truck the front right rim is sitting on the front spindle. The tires sit about three inches out further then the set I had on the truck since it was new. I ended up unable to continue because I need to do some machine work on the front calipers. That is enough of those rims, I am tired of fiddling with them
Here are a couple of blurry picks. The tires are a bit small but, that was expected after the purchase was done.
