- Thread starter
- #121
I worked on the radiator and fan today. The fan took a little bit of cutting, again it is a 1995 Taurus 3.6L fan, and it is a bit thick. It was a junkyard find for $50.00. I ended up cutting about an inch away from the mounting surface. The thing is, the mounting surface is not even, one side is about 3/4 to an inch higher than the rest of the mounting surface. I needed an even surface so I used an adjustable square and traced around the mounting surface until I met at the high spots. Then I used a die grinder with a cut off wheel and slowly cut on the line. When I finished I had a smooth flat surface. What is left make brackets to fasten the fan to the radiator and apply weather stripping to the mounting surface.
I have given thought to the Haden 2 fan 2 speed controller but, let that go when I found the DCC unit. It makes better sense the way it ramps up the fan speed instead of a relay switching on and pulling a high amp draw from the system. I ordered the DCC unit today now I wait 10 business days before it arrives. This is okay I have other things to do before i really need it.
The stuff that I removed.
The fit on the radiator. The radiator is a standard unit that has been modified into a 4 core radiator. The out side measurements are the same as a stock radiator, it is just thicker.
