Build My 1978 Nut and Bolt Frame Off Restoration
Blasted the underside; also hit the outside too. 3.5 hours, and approximately 200lbs of media. Big mess, but major cost savings doing it myself! Time to start constructing my paint booth.
img_8233-jpg.1355793
img_8234-jpg.1355794
img_8235-jpg.1355795
Ghetto, but completely functional paint booth!
Under construction. Total cost: $90
Notice, I have my helper with me. :princess:
img_8236-jpg.1356119
Late night primering.
image-jpg.1356118
image-jpg.1356120
I might also add that I bought a new gun. It's taking a bit to get used to, but I can already tell a difference between this one and my HF gun.
img_8240-jpg.1358165
Yup. Weather has been crappy. Too wet and humid to do anymore sandblasting and painting.
I am keeping myself busy. Got an Egg as an early Christmas present, and have been building a table for it.
img_8272-jpg.1363385
img_8276-jpg.1363386
img_8287-jpg.1363388
img_8339-jpg.1363389
img_8424-jpg.1367055
Blasted the interior and exterior of the tub. Then gave it 3 coats of epoxy primer. I'm using a 2-part polyurethane epoxy from Southern Polyurethanes. It goes down nice and smooth, and seems to be tough as nails once it cures, which by the way, requires 24 hours at 65 degrees or higher. Because the ambient temps were in the 30's I had to crank up a electric space heater, a kerosene heater, and run a couple of halogen shop lights. I got this little plastic box up to a toasty 90 degrees.
Boys, let me tell y'all: this thing looks good. It'll be time to start blocking/sanding this thing soon.
img_8397-jpg.1365798
img_8414-jpg.1366613
img_8415-jpg.1366614
@MScruiser, dumb question; Did you remove the plywood under the concrete after it set, or did you just leave it?
The top is formed upside down. Once it cures, all the wood and foam is removed, and the top is flipped. Because the plywood had a plastic coating on it, it leaves the surface extremely smooth.
Make sense?
Great job, I'm a few weeks behind you and can't wait to see some color. Did you decide which color you are using?
Still thinking about the earlier lighter shade of olive green. I'll do a basecoat clearcoat too.
I'm toying with the idea of doing a paki soft top too.
Soft top would look awesome. There is a ton of labor in my hardtop sides. I am leaning towards base/clear as well.
See, that's the thing; my hard top is in great shape. I'd be getting the soft top solely based on the cool factor.
Stepping up my body work game.
I've been using Evercoat and blocking with Durablocks; it's taking forever.
Here's what it looks like currently:
img_8668-jpg.1381631
Just bought this IR Airfile to make things faster.
img_8667-jpg.1381632
Got down to business today.
Here's where I'm at: I've nearly finished the first 2 coats of Evercoat and the associated blocking of those 2 coats on the outer tub.
I still need to do the final glaze coat on the outer tub. Once that is finished, I'll start on the inside of the tub (foot wells, dashboard, bed, floorboards, etc.).
If I can keep with it, I could be ready to spray my basecoat/clearcoat within a month.
Here's hoping.
img_8755-jpg.1383876
img_8756-jpg.1383877
img_8757-jpg.1383878
img_8758-jpg.1383879
I'm going through sandpaper very quickly.
img_8759-jpg.1383880
I don't own a 40, but for some reason I've been browsing this forum section lately. Your build is just impressive, one because of the attention to every tiny detail and the hours and hours of wire wheeling and scrubbing and rehabbing. But also, I like seeing the high level of quality that some people seem to be able to achieve with limited tools, time, and money...it's just amazing.
