Muffler delete (1 Viewer)
SOCAL
I was wondering if removing muffler is ok to do. I am looking to increase clearance. TIA
Its the resonator and you can remove it with no ill effects, though you may want to have an extension welded on to route the heat and exhaust away. Should be no more than $50 to have it chopped and extended.
That is a lot of rust for an AZ rig.
First 5 years of it's life in the heavily salted streets of NYC before I purchased it. Does a number on metal. Worked through and or replaced most of the problem area rust (KDSS, manifold (starter) , front LCA's). Someday I'll swap out or clean that rear axle, and replace the rear wheel dust shields but otherwise at least it hasn't gotten any worse the past 5-6 years in dry AZ desert
