MT wheels
oregon
does anyone know if the MT classic lock wheels will fit my 91 fj80? cause I saw that thread the other day on being hub centric or something. Iam thinking 15/8 or 16/8 any help is much appreciated
thanks
strap
anyone? someone has to know, I would like to order them but want to make sure they fit .
strap
I'm sure they will I'm running 15x8 Eagle 589s which are really close to those in design. Backspacing is going to be different than stock. Which in my case is great. I'm 3.25" backspaced instead of 4.25" with the 8" rim vs. the 7" rim I gained 4" total wheel track width. I'd go with the 16x8s if you could. I'm liking the idea of 16" tires more and more even though they are expensive.
thanks...anyone else have any thoughts
strap
M/T® Classic Lock
Cast Aluminum Wheel
# LARGE BOLT ON SIMULATED BEAD LOCK STYLE RING
# STEEL INSERTS IN LUG HOLES PROVIDE A STRONGER SEAT AREA
# HAND HOLES ARE POLISHED INSIDE FOR A MORE DISTINCTIVE & ATTRACTIVE LOOK
# HIGHLY POLISHED SURFACE
# CHROME HUB COVER INCLUDED
# LIFETIME LIMITED GUARANTEE AGAINST STRUCTURAL DEFECTS
Made in accordance with
U.S. Patent #6,527,346
PART # SIZE WEIGHT BOLT CIRCLE BACK SPACE LOAD CAPACITY
458401 15X8 19 5-5 1/2" 3 5/16" 2000 LB
458411 15X8 19 6-5 1/2" 3 5/16" 2000 LB
458421 15X8 19 5-4 1/2" 3 5/16" 2000 LB
450401 15X10 21 5-5 1/2" 4 1/8" 2500 LB
450411 15X10 21 6-5 1/2" 4 1/8" 2500 LB
450421 15X10 21 5-4 1/2" 4 1/8" 2500 LB
450401A 15X10 21 5-5 1/2" 3 5/8" 2500 LB
450411A 15X10 21 6-5 1/2" 3 5/8" 2500 LB
450421A 15X10 21 5-4 1/2" 3 5/8" 2500 LB
468170 16X8 22 8-170mm 4 1/4" 3100 LB
468401 16X8 22 5-5 1/2" 4" 3100 LB
468412* 16X8 22 6-5 1/2" 4" 3100 LB
468421 16X8 22 5-4 1/2" 4" 3100 LB
468452+ 16X8 22 5-135mm 4" TBA
468482 16X8 22 8-6 1/2" 4 1/4" 3100 LB
460170 16X10 23 8-170mm 4 1/4" 3100 LB
460401+ 16X10 20 5-5 1/2" 4 1/2" 3100 LB
460412+ 16X10 20 6-5 1/2" 4 1/2" 3100 LB
460421+ 16X10 22 5-4 1/2" 4 1/2" 3100 LB
460481 16X10 23 8-6 1/2" 4 1/4" 3100 LB
461170+ 16X12 24 8-170mm 4 1/2" 3100 LB
461412+ 16X12 TBA 6-5 1/2" 4 1/2" 3100 LB
461481+ 16X12 24 8-6 1/2" 4 1/2" 3100 LB
479170+ 17X9 22 8-170mm 5" 3100 LB
479402+ 17X9 22 5-5 1/2" 4 1/2" 3100 LB
479412+ 17X9 22 6-5 1/2" 4 1/2" 3100 LB
479421+ 17X9 22 5-4 1/2" 4 1/2" 3100 LB
479452+ 17X9 22 5-135mm 4 1/2" 3100 LB
479462+ 17X9 TBA 6-135mm TBA TBA
479481+ 17X9 22 8-6 1/2" 5" 3100 LB
480170+ 18X10 TBA 8-170mm 4 1/2" TBA
480402+ 18X10 22 5-5 1/2" TBA 3100 LB
480412+ 18X10 22 6-5 1/2" TBA TBA
480462+ 18X10 TBA 6-135mm TBA TBA
480481+ 18X10 TBA 8-6 1/2" 4 1/2" TBA
420170+ 20X10 TBA 8-170mm 4 1/2" TBA
420481+ 20X10 TBA 8-6 1/2" 4 1/2" TBA
Definite yes for 15x8s 15x10s and 16x8s, 16x10s will be OK but not the best.
