- Location
- United States
Up for sale: 1977 Toyota FJ40 Land Cruiser
Here is the situation; I bought this rig sight unseen. I was told that the motor was strong and it ran great. When I picked it up and took it to a mechanic, I found out that was not the truth. The motor has some flat cams, rod knock, and a leaky radiator. This rig either needs a new heart or a rebuild on the current one. I was trying to buy a turn key because I do not have a garage, time, or know-how to do an engine rebuild or swap.
Maybe you have an engine gagging for great looking rig? Maybe you just want all the parts for your engine and frame? Let me know.
Here are the details on the situation; the rig is in Bozeman, MT. I live in Steamboat Springs, CO. I went back up to my old home in Bozeman to pick-up, register, and then drive this rig back to Colorado. Well, the engine trouble did not allow me to follow through on the last part of that plan. I can get the rig down to Colorado for $500 in gas with a friend's tow rig if you live in Colorado. So, the price of the rig is $4,000 in Bozeman, $4,500 in Northern Colorado.
This rig will drive. It will go up to 40mph without trouble. If you goose it below 40mph you will hear the valve clatter, but you can drive it carefully up to 40mph, not tax the engine and not hear the clatter. If you go much over 45 you are reaching the RPM limit on this set-up and you will hear the clatter.
Now to the good stuff, the following is a description of the components of this rig:
Mid-80s Chevy 350, electronic ignition, original Toyota radiator, new plugs and wires, Edelbrock Carburetor
The previous owner said there were only 60,000 miles on the engine. My mechanic says it looks like 150,000. The engine starts quickly. It idles well. It runs smoothly up to 3,500 rpm.
It has a lot of power (climbed a 6" step to get on the trailer just by letting out the clutch).
Flat cams on the cam shaft, two cylinders have their exhaust valves only open part way. You can hear the valve clatter above 3,500 rpm. Rod knock above 4,000ish rpm. Small crack in exhaust manifold. Leaky radiator.
Chevy 4 speed transmission
Granny gear. Works well. The slave cylinder looks to be new and needs to be adjusted. Right now the clutch contacts very close to the floor.
Toyota Transfer case
Works well. No issues.
Spring over Axle (SOA) has been completed
Shackle Reversal has been completed
Saginaw Power Steering has been completed
33x9.5 tires on steal rims
3/4 Aluminum Tub
Solid doors all around
There was some rust on the bottom of doors. It has been blasted down to metal, primed and painted.
Solid hood
Steel Fenders
One small hole hidden by blinker.
Fresh paint
Old top
The sides look great but the roof needs work. There are holes from a wheel being mounted to the top and a rack.
Edit: freewheeling frank just stopped by to have a look. He thought the top that is on it may have come from a rig earlier than 1977. He thinks that if I or the new owner put on the spare windshield frame that is included with the sale, the roof will fit better.
Extra parts
1. New windshield frame and gasket
2. All new door gaskets
3. SOR bikini top and soft doors
Here are some photos:
More photos can be seen at http://photobucket.com/1977ToyotaFJ40
Terms of the sale:
- Cash or Certified Check only.
- $750 non-refundable earnest money needed to hold the rig.
- I can work with you on pick-up within 90 days of receipt of deposit.
- I will not back out of a deal made, but the buyer may at any time. They will forfeit the earnest money unless another agreement is reached.
- I understand circumstances that are out of your control and I am willing to work very hard to resolve any issues so that everyone is treated fairly.
- We are all in this together and I understand better than a lot of people what it feels like to be lied to during a vehicle purchase.
Please let me know if you have any questions.
3/4 Aluminum Tub
Solid hood
Steel Fenders
Fresh paint
Old top
Extra parts
Terms of the sale:
