how much of a difference will you see?
not enough to think you'll make your money back on the cost of one
there are other reasons to install one
What kind of MPG difference do you think you will seeI had consider this mod… @wngrog gave me the best advice I could find. It’s a bigger modification to the tunnel cover and my best option in his thinking was to swap the 4.11 gears in the diff to 3.70. I have acquired these differentials and will be making that swap this summer.
It should have been finished by now but an option popped up for another project that took 6 months to finish so I’ll document the before and after stats when it gets completed. Hoping to start early April ‘25
Wow, I was hoping for better. This is my son's daily driver. He gets about 13-14 doing 65. Doing 75 he gets 11-12.I am running (stock for my year) 3.70 diffs, 33" tires, and an H41 transmission (same 1:1 4th gear as the stock H42). It gets 11-13 mpg combined local & highway driving. One tank on a long trip, going a fairly steady 65 mph with a consistent tailwind, I got 14 mpg.![]()
Jason,Unfortunately I don’t think you will see much or any at all. It depends I guess on your tire size and what kind of driving you do interstate vs around town. Maybe for long trips when you are in 5th gear for long periods of time you might see something. I’m only driving around town with very little interstate driving so 5th would pretty much be useless for me. I’m on 31” tires and stock gearing. Maybe 33” one day. I kinda gave up on mpg a long time ago and just enjoy the truck for what it is. It’s about smiles per gallon right!
Jason
what other reasons?not enough to think you'll make your money back on the cost of one
that is crazy - I would have thought that with as high as the engine is revving with the 4 speed at 65 MPH, by adding a taller gear in the 5 speed, there would be a huge rpm reduction, thereby increasing fuel efficiency.You will have to drive like grandma to see a gain. And then it begets the question of whether you would have got the same result just driving the four speed in eco mode?
If you lug the engine below optimum torque, then you’re losing efficiency. And if you try to drive fast enough with an overdrive to reach optimum torque, the increased wind resistance against the vertical wall of a 40 windshield kills mpg.
I wrote an article in Toyota Trails about this almost twenty years ago.
I honestly don't know what diffs are in our FJ. It is a 1973 body, but 78 2f, tranny and tcase
Wow, I would have thought that with as high as the engine is revving with the 4 speed at 65 MPH, by adding a taller gear in the 5 speed, there would be a huge rpm reduction, thereby increasing fuel efficiency.
THanks for educating me!I think you are overestimating the overdrive 5th gear in the H55, it's a modest reduction - 0.85:1, i.e. only 15% higher than 4th gear.
Are you saying that you have an FJ40 that got 28MPG? If so, was it a diesel, or did you have to push it over a 8% grade for 30 miles to get that?"Avoid excessively high speeds. The difference between 50 mph and 70 mph may save 15 to 20 percent on your fuel bill." - 1975 Land Cruiser Owner's Manual.
I get as much as 14 or 15-mpg with 2F, 4.11s, and 215/75/R15 during summer. It was on a switchback highway up and down the mountain (35-mph max speed posted). A non-USA OEM 2F carb that I installed scored about one-mpg more than the richer-jetted OEM '75 Aisan. If I had the 2F-EGR hooked up it would probably buy an mpg or so? My other rig was specified as 28-highway EPA-estimates, but, I did as much as 33, with a partial emissions delete. This is at 7,000-ft. plus - your location is more efficient for internal combustion engines.
