Mounting points for 70 series factory flares
dogfishlake
"Go on a living spree"
Supporting Vendor
greenville mi
I am going to add factory flares to my HZJ-73. I know it is quite an expense and a task, but I am a total fan of the look, so that is that. I have 2 new flares from Toyota and 2 originals. I also have what I believe are all of the different metal clips that attach them. The big fun ahead is getting them mounted in the proper locations.
I plan to go about it by mounting the flares by the two holes on each end of each flare to establish proper location. When that is done, I am thinking of bolting the little metal tabs to the flares and then coating them (gooping them) with something like silicone and mounting up using the two mount holes, and perhaps some tape to pull the top of the flare to the body. After the silicone is cured, I will unbolt the tabs and hopefully pull the flare off with the tabs stuck to the body so I can drill for rivets. After the holes are drilled, I will need to clean up the silicone mess, coat the exposed metal, then rivet on the tabs.
My questions are:
Does anyone know how Toyota attached the flares through the front and rear mount holes? i.e. are they just sheet metal screws? Rivnuts?
Is my idea a good direction? or am I missing an easier way.
Any knowledge, picture, or advice is greatly appreciated!
Hello,
The flares mount on the fender with mounts. Some have a hole and others have a captive nut.
These mounts are riveted to the fender.
Fenders and support mounts are available from Toyota. It is better to go OEM on this.
Juan
Fender brackets are riveted to the bodypanels
Hello,
Juan
Thank you. Yes, I am going OEM. I have all of the mounts, as far as I can tell. I just have to devise the best way to discover the rivet locations. I thing the "glue on" method will work- only to locate their positions.
What about the two holes that go completely through the flare- one in the front, and one in the rear. Do those go into a bracket as well? They look like they screw right into the fender or quarter panel
These buggers (front flare in this case)
Hello,
The front hole is for a bolt.
The small rear hole is for a screw that keeps the mud flap in place. If I remember correctly, the big hole is for a mount stud.
If I remember correctly, it is four bolts and a screw for the front fender flare. The rear uses four bolts and a screw as well.
Each flare has cone-shaped stubs that fit into the mounts that do not have captive nuts.
It is possible to mark the location of the mounts from the flare. The measure twice, cut once rule applies.
Juan
Bummer. I really thought these would be direct mount, but now I see what you mean. Those are brackets too
Hello,
Juan
I might measure 4 times😅
Thank you
Thank you
Hello,
This is how the flare is mounted.
Make sure you get the non-captive-nut brackets/mounts right. Otherwise, the captive nuts will not align with the bolts.
When mounting the flares, align the stubs first. Then try the bolts.
Remember: the mud guard uses a self-tapping screw. The flare uses bolts.
Last but not least, do not forget the seal strip.
Juan
This is what the front bracket looks like. I replaced my rear quarters and cut out a section of the old quarter to use as a template but for both bottom mounts there was no metal left so I used 2 side tape on the bracket and attached it to the flare.I put the flare in place and the 2 sided tape held the bracket until i could drill holes and rivet it in place.I'm too impatient to wait for glue to dry.
Thank you
