Motor mounts for 4BT
Looking to fab up some motor mounts to put a 4bt into a '76 fj40 but saw that there are some mounts for the 3b floating around does anyone know of anyone selling the motor mounts for the 4bt? Thanks
Rock auto has both the solid and fluid filled ones. Have to search for the part numbers though.
Toyo - I have the same 4bt swap in process now. I could not find any existing mounts, so I fabricated my own. Will shoot some pics of my mounts to you this evening.
I used 2F engine mounts.
If you do some deep research on the "Lords" and other brands of fluid mounts, you will find they do not hold up to angles very well.
You generally want your engine mounts to be the same material as the transmission mount.
Sent from my iPhone using IH8MUD
I use the fluid filled motor mounts and kinda wished I'd used something a bit more stiff since I can feel the motor shift a bit. Have you checked out the ones on Dodge pickups running the 6BT?
