Sorry for more questions but got to ask.
1) Truck started running kinda ruff so i went ahead and replaced all of my vacuum lines and that did not help. They needed it though. Took out the FSM and made sure all of them were right. Tested vacuum switch for fuel cut and tested fine, however the same thing it is supposed to do when you pinch the hose it will do when the truck is warmed up. Not when the truck is cold mind you just when warmed up to op temp. Does it at about 1400 RPM's.
2) Next thing i did was plug the top vacuum hole on the EGR valve and see if the truck would run better, as it had alot of hesitation and not liking hills anymore at all. Of course it ran better but now it does not want to start when it is cold out, even with full choke it takes some playing with to keep her running till she warms up. Once she warms up she runs like a skalded dog, which is a good thing. Any idea why she is so hard to warm up now ?
Thanks for any and all help / ideas.
