Misfiring
Bay Area, CA
I've recently did replace all the parts related to the EGR under the intake manifold. While doing so, I had the fuel injectors cleaned and reinstalled. I got the engine to start last night and it was misfiring. I did break the connector for the knock sensor #2. The exhaust pipe after the cat was hot/orange.
Could the knock sensor cause the engine to misfire? CEL P0330 is what came up?
Does Toyota sell the Knock sensor connector w/ pigtails?
If not, what options so I have?
Thanks in advance.
Is it a random miss or a constant miss? Check the injector clips are on all the way.
Are all of the injector connectors on the correct injectors? Is the harness tied in place, not rubbing on the EGR pipe?
Toyota sells the connector, don't have the numbers handy. We have used the replacement sub harness for the knock sensors on the 3.slo. They are common, cheap and have two pig tails to harvest.
