Hey all, whats happening?
Been reading this forum for years but never really have gotten active on it. Figured I should start considering I shelved my Toyota Cressida and can't really talk on that message board anymore, but anyway....
So I just completed a full cooling system service on my 89' FJ62. New radiator, OEM Belts, hoses, thermostat, fan clutch, Waterpump, and a complete system flush. The Aluminum radiator looks purdy....
So the first time i fire it up, i let it get up to operating temperature and let it sit for about 30 minutes before i back it out of the garage. During that time not a SINGLE DROP came out of the whole truck. Figured i was gold, but then when i pulled it out and parking it in front of the house (maybe moved it 15 feet) i notice the drip trail heading down the driveway following the path the truck went... uhg.... well, it suddenly got a steady drip from SOMEWHERE around the waterpump/outlet, but since its 2AM I said screw it, i'll check it out in the morning..
So apparently the leak stopped shortly after i shut her off, because it barely lost any coolant at all and the pan i put undernieth it didn;t look any more full from when i shut it off...
So i fire it up... of course nothing, so i take it out for a drive and when i return, its got a steady slow drip again.
Problem i'm having is that i can't determine WHAT in particular is leaking... Those familiar with the 3FE know that Toyota completely BURIED the waterpump so theres no real way to inspect it.. all i can tell is that the leak only is there when its HOT and that it runs down the lower radiator hose, and down the timing chain cover... I have tried poking a paper towel around in an attempt to find it, but no luck.. My guess it its the lower hose on the pump or the pump gasket itself... Grr..
I guess what i'm trying to get at is has anyone else had this happen? I took a good two hours cleaning up the block mating surfaces and used OEM gaskets and the FSM for the work, but im HOPING that since its only during certain times that maybe its one of the hoses and not the pump itself? i would hate to tear it back out if i could avoid it, but its gonna need another minor teardown of some sort just to get to those hoses...
I've never had a waterpump leak on me afterwards, so i guess i'm just trying to get some pointers to see if anyone has had similar results...
If not then i'm going to double clamp the hoses and get some sort of gasket dressing i guess. anyone have experience with those? not so much silicone, i am avidly against it unless it is required, but i would hate to have to do this a third time... Thanks in advance
